alright guys im running an aq1200 and a pheonix gold zx450. sub amp is 1200 rms and 4 channel is 75x4. my under hood battery is small and i also have a 1 farad cap in the back with both amps hooked to it. my buddy wants to buy a cap so i was thinking of selling him mine and getting a kinectic or xs power battery for the back ( or front ) so here are my questions.
1. will adding a battery in the trunk cause additional stress to the alt?
2. how would i wire the battery in the back? front + to the rear + and just ground the back battery in the trunk?
3. should i use this under the hood? http://www.audiosavings.com/products/Car-Battery-and-Power-Cells/XS-Power-D680-1000-Amp-AGM-Power-Cell-Car-Audio-Battery--Terminal-Hardware/D680.aspx
or do something smaller in the trunk like this and keep my stock battery? http://www.audiosavings.com/products/Car-Battery-and-Power-Cells/Kinetik-KHC600B-Power-Cell-Car-Audio-Battery-System,-High-Current,-600w-HC600B/HC600B.aspx
4. will a 200 amp fuse be good for my big 3 upgrade? i have a stock alt and ill be using cadence 1/0 gauge for my big 3 wires
i think thats all my questions... for now lol. just trying to get everything set up correct and not break the bank if possible. thanks in advance for any answers ! :drink40:
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
1. yes (how much is a different topic all together)
2. you can ground in the back, better to do another run of -
3. I would add the battery in the back, then down the road replace your stock under the hood.
4. Fuse to the wire, not the equipment it's hooked too. If you wire is rated for 300amps, fuse for 300amps.
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
1. if you drain your batteries yes.
2. positive front to positive back, make sure to fuse this. negative front to negative back if you have enough wire, if not ground in the back from the back battery.
3. i'd get a second battery for the back first then switch the front bat when possible.
4. fuse size is dependent on wire. not sure what cadence wire is like.
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
alright thanks guys. ill have to look into what cadence is rated for and for a daily driver and only listening to my system while driving the batts wouldnt drop crazy low right? and would the smaller kinetik battery in the back work fine or should i go with the xs power?
New build :
same amp
Would the voltage drop low overnight with them both hooked up?
New build :
same amp
Yea. I wont be playing it with the car off. Only when driving. And just wanna make sure the voltage won't drop crazy low while parked overnight. Im not sure how these batteries work compared to normal ones.
New build :
same amp
well they function the same. They won't discharge over night so no worries there. Or at least, they won't discharge any more than your battery now does.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 804 Guests (See full list)
