gally Posted December 18, 2011 Report Posted December 18, 2011 hmm....think i have the dumb today but i understand it....si i was lookin at something like THAt Foam is great for isolating trim and preventing and stopping rattles, but to act as an absorber you would need several inches worth of form to do any good. And I'm not talking 1-2 inches, it's more like 6 + inches and that's just not going to happen in a car. Thats why it's more effective to use a thinner but much denser material like mass loaded vinyl to BLOCK the sound instead of absorb it. so you mean like deadner over damplifier??? over that is there any way to totally isolate the sound (like loud music)....i mean to isolate it so that you cant hear from outside of the car that much? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Second Skin Rep Jon Posted December 18, 2011 Report Posted December 18, 2011 Mass loaded vinyl really isn't deadener, but rather a noise barrier or sound blocker. But yes if you use it in conjunction with a vibration damping mat it would help isolate the sound and prevent it from being heard outside the vehicle. Especially so if you install it INSIDE the door cavity, behind the speakers. But just like everything in this world there are limiting factors and in the case of vehicles, it's the glass/windows. You will still be able to hear the music through the glass of the window... Have a question about Second Skin? E-Mail me!
gally Posted December 18, 2011 Report Posted December 18, 2011 so...dynamat is expensive....your damplifier (not damplifier pro) is in a normal price as silent coat the normal one(2mm)...guess i will go with either SS damplifier or silent coat..but i will need A LOT of that sheets...(and my budget for car audio stuff is like 150-250€ a month) 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
gally Posted December 18, 2011 Report Posted December 18, 2011 Mass loaded vinyl really isn't deadener, but rather a noise barrier or sound blocker. But yes if you use it in conjunction with a vibration damping mat it would help isolate the sound and prevent it from being heard outside the vehicle. Especially so if you install it INSIDE the door cavity, behind the speakers. But just like everything in this world there are limiting factors and in the case of vehicles, it's the glass/windows. You will still be able to hear the music through the glass of the window... ok guess i will go with silent coat...then... oh yeah. one more question if you apply one layer of sound deadning material for example on a door like the 2mm foil...can you just add another 2 mm on top of that? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Second Skin Rep Jon Posted December 18, 2011 Report Posted December 18, 2011 if you apply one layer of sound deadning material for example on a door like the 2mm foil...can you just add another 2 mm on top of that? You can, but the term "diminishing return" comes to mind. 25% coverage with a sound deadening material is really all that is needed and 100% coverage is the maximum you should ever do. Multiple layers is just wasteful. Have a question about Second Skin? E-Mail me!
gally Posted December 18, 2011 Report Posted December 18, 2011 if you apply one layer of sound deadning material for example on a door like the 2mm foil...can you just add another 2 mm on top of that? You can, but the term "diminishing return" comes to mind. 25% coverage with a sound deadening material is really all that is needed and 100% coverage is the maximum you should ever do. Multiple layers is just wasteful. so...if i get a 2mm foil over a 4mm foil would just get better with one layer of it? is that just because the 2mm fiol is more thick than a 4mm? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
