help me finish my system
1) what up dudes i need some help.... i have 2 sets of cadence components (will post links of each) and i wanted to run em off a 2ch amp, whitch of these 2 amps work? (will add link) they will be ran at 2ohms...i do not want to blow my speakers so witch one would you get between the 2..THANKS!!!!
Amp- Lanzar MXA214 2-Channel Max Series Car Amplifier (MXA-214)
Amp- Lanzar MXA224 1000W Max, 2-Channel Max Series Amplifier (MXA-224)
Comp- CWM6KIT - Cadence Sound Store
Comp- Cadence ZRS55KS Component Systems at Onlinecarstereo.com
2) need some help....have a look at my rca?? will post 2 pics both of booty shots and see if i hooked it up correct, if i didnt the 2nd pic is blank so you can draw out the rca.....first time using 2 amps, eq, and epicenter so i dont know how to connect it all....THANKS!!!!
PICS
i would get Lanzar MXA224 but if you realy want to play it safe get the other one, as for question 2 i cant help with that
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
