How much does the cone of a fi 18" bl and 18" sp4 bounce up to?
Vooloco
you should be using sd not the area of a 12/18" circle.
if you are multiplying by the same xmax whichever is the largest cone area will have more vd. again tho, this doesnt determine which will be louder, just which can displace more air on all notes.
sd is cone area, assuming proper measurements were made. The numbers in this thread are all pretty much junk though. Cone area is a linear measurement btw, dont measure the depth of the cone and calculate it as a true cone, just as a flat piston.
sd is the effective piston area...
the area of a 12" circle is 729.288864 cm^2, yet the sd of a 12" sub is 480cm^2... so it matters A LOT when comparing different size sub setups
Which is why I said "assuming proper measurements were made". 9.7" diameter is a bit large for a 12" cone though.. center-to-center on the surround is the agreed upon measurement point I guess though ; )
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 770 Guests (See full list)
