I have a 2003 Ford Focus se. 4cyl sohc 122 cid. I need to put a second alternator in. But I am tight on room. Is there a way to still put one on? It comes stock with a 110amp alternator. Is there a way to get a bigger amp alternator that will still work on my car? Any suggestions on what I could do???? I put my second kenwood performance series 1,800 watt amp in and when I get bumping I can feel my car loose power. It is like the engine is loosing power. Then when the bumping stops it goes smooth. I have a 10 farad capacitor. 0 gauge kicker wiring kit. Any suggestions to how to set up the power I need to handle it.....
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
Just upgrade your stock alt with a high out put one
Look into DC power, mechman, and singer alts. They should have one that fits your vehicle
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
So far I have just looked at part stores. Napa seemed to be the only ones that knew what I was talking about. But, from what I see. I will have to find one on-line and order it. Un-less there is a store that could have them or order it... I was told if I could find at-least a 150amp I should be fine. Since as of right now I am only going to have 2 kenwood performance series 1,800 watts amps. Think thay say at 2 ohm that I am running 800 or 900 rms.
