Smoove Posted December 23, 2011 Report Share Posted December 23, 2011 I want to get the max performance out of my amps (14.4v). I am wondering if my setup will work. 200amp powermaster alt 200amp stinger battery isolator 12v optima redtop. Primary battery for truck 14 XSPower D1400 as secondary battery for amps Will this work? Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
nbshazeezee Posted December 23, 2011 Report Share Posted December 23, 2011 you want to mix different voltage batteries for you setup? Quote Ye dig, getting loud off little (2) AQ HDC3 12 AQ 2200D - Replaced it, Works great AQ4x90 JBL 662s 2 ways (2)XS 5100r under the hood & A 170amp alt Link to comment Share on other sites More sharing options...
toad559 Posted December 23, 2011 Report Share Posted December 23, 2011 it should work if you wired all the d1400 together only and then jus hopt a - and a + to a single connection for the run or burp or bassrace. then disconnect it from the 12v batt and jus charge it with the 14v charge all in paralell. they do rest at around 14-15v. it might be ok if you jus o it strictly like that. but it might jus sae u the trouble if ur car can take a 16.8 charging system Quote Fresno, Cali 559 Link to comment Share on other sites More sharing options...
toad559 Posted December 23, 2011 Report Share Posted December 23, 2011 or if ur buying that much batts, jus get d1600 cant jus hook it direct lol for a burp and unhook it back to 12v for daily lol. Quote Fresno, Cali 559 Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2011 Author Report Share Posted December 23, 2011 Only if it would work. Or is there a better way to get to 14v for my amps? Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2011 Author Report Share Posted December 23, 2011 I want to do this in a daily driver with 4 fosgate amps. 2 500.1 and 2 500.2 Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
nbshazeezee Posted December 23, 2011 Report Share Posted December 23, 2011 just make sure you alternator is good, and you have a big battery bank. and running 12volt batteries you should not drop below 14v if all it well Quote Ye dig, getting loud off little (2) AQ HDC3 12 AQ 2200D - Replaced it, Works great AQ4x90 JBL 662s 2 ways (2)XS 5100r under the hood & A 170amp alt Link to comment Share on other sites More sharing options...
tlee2 Posted December 23, 2011 Report Share Posted December 23, 2011 Only if it would work. Or is there a better way to get to 14v for my amps? Yeah, have no voltage drop. Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333 Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2011 Author Report Share Posted December 23, 2011 So would be dual d3100's for the system be better I am still new to doing power correctly so my head lights dont dim when the bass hits. I dont want distortion or lack of power to the amps because I didnt build the correct electrical Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
tlee2 Posted December 23, 2011 Report Share Posted December 23, 2011 With what your running a 200 amp alt 2 3100s and proper wiring should be plenty Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333 Link to comment Share on other sites More sharing options...
