I want to get the max performance out of my amps (14.4v). I am wondering if my setup will work.
200amp powermaster alt
200amp stinger battery isolator
12v optima redtop. Primary battery for truck
14 XSPower D1400 as secondary battery for amps
Will this work?
you want to mix different voltage batteries for you setup?
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
it should work if you wired all the d1400 together only and then jus hopt a - and a + to a single connection for the run or burp or bassrace. then disconnect it from the 12v batt and jus charge it with the 14v charge all in paralell. they do rest at around 14-15v. it might be ok if you jus o it strictly like that. but it might jus sae u the trouble if ur car can take a 16.8 charging system
Fresno, Cali 559
or if ur buying that much batts, jus get d1600 cant jus hook it direct lol for a burp and unhook it back to 12v for daily lol.
Fresno, Cali 559
Only if it would work. Or is there a better way to get to 14v for my amps?
I want to do this in a daily driver with 4 fosgate amps. 2 500.1 and 2 500.2
just make sure you alternator is good, and you have a big battery bank. and running 12volt batteries you should not drop below 14v if all it well
(2) AQ HDC3 12
AQ4x90
JBL 662s 2 ways
So would be dual d3100's for the system be better
I am still new to doing power correctly so my head lights dont dim when the bass hits. I dont want distortion or lack of power to the amps because I didnt build the correct electrical
