smoothug Posted December 26, 2011 Report Posted December 26, 2011 Hello I need help building a new box with 4 smd's with 12k going to them. My box I want is H20xW45.5xD40 I need to know if this is enough space as well as how much port area do I need for tuning at 30-35 hz. Please help. Thanks for all your in put..
pwdrblucivic Posted December 26, 2011 Report Posted December 26, 2011 I believe you are going to need a little more room than that. I put those numbers into Torres and after taking out a decent size port and other displacements that box would be about 13 cubes net. Ascendant recommends 4-7 each on the 18s. I would try to get as close to 16 inches of port per cube if at all possible. Someone else may chime in that has ran the SMD subs in a smaller than recommended enclosure. Good Luck!!!!!
smoothug Posted December 26, 2011 Author Report Posted December 26, 2011 I believe you are going to need a little more room than that. I put those numbers into Torres and after taking out a decent size port and other displacements that box would be about 13 cubes net. Ascendant recommends 4-7 each on the 18s. I would try to get as close to 16 inches of port per cube if at all possible. Someone else may chime in that has ran the SMD subs in a smaller than recommended enclosure. Good Luck!!!!! tnx ok how about this 22x45.5x43 and how much port area are u using with this?
pwdrblucivic Posted December 26, 2011 Report Posted December 26, 2011 I tried it with 22"h x 45.5"w x 43"d and came up with just over 16 cubes......port size was 5.5" tall x 44" wide (port at bottom of box) and about 22" deep.....That would tune it in the area of 32hz with 14.5" of port per cube....
TRTC360 Posted December 26, 2011 Report Posted December 26, 2011 Is this a dream build or do you have amps subs batts and alts in hand already? If so i want pics!! '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
fecupe2001 Posted December 26, 2011 Report Posted December 26, 2011 Is this a dream build or do you have amps subs batts and alts in hand already? If so i want pics!! Exactly my thoughts lol I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
smoothug Posted December 26, 2011 Author Report Posted December 26, 2011 Is this a dream build or do you have amps subs batts and alts in hand already? If so i want pics!! Exactly my thoughts lol ok no its not a dream build and yes I already have most of the stuff in my truck now Im running two tc 18's lms on a ia 40.1 at .05 with 5 batts I have two 200 amp alts and a mla module already I'm looking to upgrade that system and i will post or send u pictures when i start my new build I just need two amps to push the 4 smd's. I hoping to get two 12k's and two new alts 270+ and 4 more batts.
