Okay. So I have been noticing that my subwoofers will start out quite and then all of a sudden while I am driving they will get a lot louder? Why is this? I use to think it was because my battery wasn't warmed up but that's not it because it takes like ten minutes and my car gets warm in like 2 minutes. Hope you can help.
a couple things come to mind
your alt kicks in and gives a couple volts more now and then
you have a loose power terminal
you have a bad RCA pair where one goes in and out
I'm sure there's more to look at, someone else will chime in I'm sure.
2007 Pacifica
Any amplifier with an unregulated power supply (which is most amps) will give more to your speakers if they're getting more voltage. Watch your voltmeter (you have a voltmeter, right?) and see if there's a correlation with it and the random volume bump. If not, then take a look at the other things I said.
2007 Pacifica
I have a volt meter but i have it un hooked. I will hook it up tomorrow and check it out. And no it. Once it gets loud it stays loud. But until then it is quiet.
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
