DC Sound Lab
I already did cut it but i figured i wont be able to use that since it tapers up a little... How would i get the measurement for that? i havent had any time to play with the calculator or take more measurements cause i'm pretty busy at work.
in my sonoma i took everything out of the sides and i can get 56 in wide right under the window line and if its gonna be a wall then wont the specs be bigger cuz those specs are about what a big square box is in your cab and if you do a wall you will prolly build inside and take up as much room as possible besides were you put your amps if there in the cab
Edited by jakobebassbudds
2 12ks and i dont know what to do
build in the works!
U am going to have my setup as a daily... i actually am going to wall it, thats why i'm going sub forward port forward... My truck is 3" traditional bodydropped so i loss sone airspace... A friend told me if i am going for a daily, i should have the port on top facing forward for best results. the max space that i have in my cab is 33.5h x 46w x 19d... i figured i have the depth of 17" for the box so i can drive comfortably.
shit im a big boy so im not going over 15 deep to be fully comfortable lol
build in the works!
The specs would be bigger... i can actually make the wall wedged because of my seat position but i figure that it would be easier to make a square wall instead...
Jako - is your truck with the third door? my amps will be in my bed.
Edited by nosho47
Yes with your style of dime a wall 50.5 will fit. But it will be tight!
2011 Meca World Champ S3
Team Truth Hertz
Team DC
It is not. I cannot find a pic with the wall in it. But heres a pic of a box that was in it that was 50.5 wide. And one that you can see the amount of plastic that was cut out.
Team Truth Hertz
Team DC
I finally got the chance to play around with the torres calculator a little more today... LMK what do you guys think of this? I think I'll try it at 6.35cu... I just hope this will sound good.
  • Who's Online   1 Member, 0 Anonymous, 705 Guests (See full list)
