So I just bought a kicker l7 15" sub and its the DVC 2 ohm version. I have a brutus 2000 watt hifonics amp (25th anniversary edition). I'm not sure if wiring the l7 at 1 ohm is too much? Because wired at 1 ohm it says is 2000 watts rms which is way too much. But wired at 4 ohm is only 650 watts rms which would be under powering it. What should I do?
get a second sub or under power it. over power it and just keep the volume down and adjust the gain right on the amp. its up to you. do you want to have to replace it or keep it?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Itll still get very loud at 600 watts especially if you have the proper box built for it. I would sell it locally then buy two 4 ohm dvc used and build a box and they will bang.
If your set on 1 then build a cool 4 cubic box tune to 34hz. If you decide to get another 2 ohm sub then it will be tough to find an amp that does a lot of power at 2 ohms but i would get the audiopipe 3000d it does 3000 true rms at 2 ohms.
You can even get two more 2 ohm dvc and wire them down to 1.3 ohms and run them with a stronger 1 ohm amp.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
