Hi guys. The current set up is 1 kicker ZX 1000.1. Rated power is 500watts @ 4ohms and 1000 Watts @ 2ohms. I have 1 MX18 D2 sub that is currently wired @ 4 ohms. I have another off brand 2 channel amp powering some highs.
I just got a MB Quart 125x4 . 2 channels can be bridged to put out 500 Watts @ 4 ohms. My question is can this amp effectively replace the 2 I have installed?
I don't have any cash to upgrade to a suitable amp for the MX18 in the foreseeable future.
What do you guys think?
I wouldn't run the sub off that amp just use it for your mids and highs and leave the other one for the sub
x2
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
Why not wire the sub to 1 ohm and let that ZX1000.1 actually give it some power? I know Kickers say only stable to 2 ohm, but I'm sure you will be over that with rise. I wired mine to 1.34 and it loved it all day! Loudest I ever heard that amp, NEVER protected or shutdown in any way. But I think that depends on how stout your electric is also.
Anyway, whatever you decide to do, good luck! :drink40:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
Some have success with wiring those amps below the recommended ohm load. I, on the other hand, don't have success with the kicker amps being at 1.4ohm or below. It will protect on me. So I will not recommend the 1ohm nominal.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
