DLS SD52 2 ways
Cardboardcat15
I just picked up a pair of the DLS X-SD52 5 and a qurter components from sonicelectronix the other day. I got them this morning and I took them out of the box to hook them up. Well now I'm having a small issue with wiring. On the instruction manual, found here http://www.sonicelectronix.com/item_26473_DLS-X-Program-X-SD52.html (scroll to the bottom, it's a PDF. I have the DLS X-SD52) The intructions show to wire the woofers + and - coming from the crossover to ONLY the - coming from the amp, and wiring the tweeter + after the crossover directly to the amp and then the - inline with the - coming from the amp. This obviously made no sese to me, because to ym knowledge it isn't a parralel/series wiring. I did it anyway, and I only got sound from the tweeter. when I probed it with my DMM I didn't get a load. However, when I just wired the tweeter and woofer in parralel after the crossovers and then connected them to the amp, I got sound from both speakers and they sounded great actually. I probed it with the DMM and got a nice even 4 ohm load.
So has anyone had experience with these speakers? Am I doin it right?
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
If it works the way you did it, keep it that way. Just make sure to check the ohm load the amp is seeing with the way you have it.
EDIT: I see you checked and got 4ohms. Should be good to go.
yeah I figured it would be fine, just wanted to check. Dont wanna waste 140 bucks. It must be a printing error on the manual. Gonna go ahead and start my kicks then.
I'm still waiting on my disbursement check :( Once I know if it's enough to cover books and a parking pass, I'll let ya know. The check was supposed to be deposited today >:l
  • Who's Online   0 Members, 0 Anonymous, 1446 Guests (See full list)
