Underhood or both?
I am going to be installing my amp and sub in the next couple weeks, but am a little confused on what size(s) of batteries(s) I should run in the car.
The car is a 1998 Mercury Sable, I have already done the big 3 setup in 2/0, but keep thinking that when I go to run almost full power the voltage is gonna plummet! My factory alt is 135 amp, which upon research should be good with 1000-1500rms which I will be running. I also am running 1/0 towards the amp, then into a 1/0 to 4 gauge adapters in the amp.
So my question is should I buy an underhood battery that is stout, or could I just run a smaller secondary next to the enclosure.
Thanks guys, been pondering this for a while!
Mike
The amp is a Tru Technology H1 Hammer pushing a single 12"
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
Im just trying to figure out a good size, not looking to break the bank, but still keep the voltage in check!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
Personally Id up grade underhood AND get a second battery just to be on the safe side. Either way you do it you're going to have voltage drop from your alt to the rear. Having a battery in back will just minimize it.
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
look up ram designs on here he has some upc batterys that compair to a batcap 2000
  • Who's Online   0 Members, 0 Anonymous, 965 Guests (See full list)
