LT1Roadmaster Posted December 30, 2011 Report Share Posted December 30, 2011 If everything was working correctly before the battery change then its defiantly the battery. Double check the connections and make sure Its fully charged. Quote Link to comment Share on other sites More sharing options...
bhirst Posted December 30, 2011 Report Share Posted December 30, 2011 When checking your connections I'd also make sure they are clean and secured properly. Quote http://Bhirst.com My portfoilo and blog! 2005 Nissan 350z with an iPad install and a dd 2508 http://www.stevemead...ll-and-dd-2508/ 2002 Chevrolet Cavalier http://www.stevemead...n-half-for-fun/ Link to comment Share on other sites More sharing options...
SPL Blazer Posted December 30, 2011 Report Share Posted December 30, 2011 had a friend swap his battery and it did the same thing, the connections looked good and his battery was at 12.6, but wouldn't start the car. Turned out the connection at the terminal wasn't tight enough. Took it off and reinstalled the wires and it started right up. Quote 2001 Blazer ~ (2) 10" DC lvl 4's, Orion 2500d 148.9db 2005 Astro ~ (2) 18" DC XL's, Atomic 5000.1 153.9 db New England SPL NESPL - YouTube Link to comment Share on other sites More sharing options...
Go-N-Def Posted December 31, 2011 Report Share Posted December 31, 2011 happend to me i put wrong terminals on but everything worked. car didnt start. Quote Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL Link to comment Share on other sites More sharing options...
95legwagon Posted December 31, 2011 Report Share Posted December 31, 2011 clean both terminals also with a terminal brush. sounds like a bad connection if your sittin @ 12.5v ...... my car starts sittin @ 11.2v and i would take a look at where the wire connects to the terminals too..... corrosion would do it. just had a car come in at work (88 mercury marquis) was sold to us CHEAP "not running" i messed with it and found out the wire from the pos. terminal to the starter solenoid was shot ( 1 ft wire) so i jumped it from the solenoid and it started right up. work FTW. not trying to thread jack lol just showing how something so stupid can cause this. good luck Quote i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq Link to comment Share on other sites More sharing options...
