Well for my car I can only fit on alt and it 220a. I was think maybe Xs 3100 for my starter and a 3400 in the back maybe too.
call/email Mechman/DC Power and find out what they offer for your car as I assume the 220a you are mentioning is the PowerBastards alt.
I am running a DC Power 320a HP an upgraded front batt and 2 rear batts with 5k rms...no issues with daily pounding at all.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
You'll have to do a little research yourself, but I'll try to give you the basics. You want to start out by finding out how many amperes your amps are gunna pull. The manufacturer will usually tell you what it uses at RMS, if they don't you can go by fuses. Add the fuses up and you get an idea of what it will pull. Once you get that number, you can put together a little shopping list for electrical. For six thousand watts you're probably going to be pulling around 350-400 amperes maybe even more. So you're definitely going to have to get a HO alternator or two. You want to find an alternator that will be able to supply both the amps and the car accessories without being taxed. If you can't get a dual alt setup or don't want to do a dual alt setup, which a six thousand watt system will probably require.. you can add a bunch of extra batteries to help that one HO alt. The extra batteries will give the amps what they need and at lower power times the alt will have a little time to recharge the batteries slowly. But if you are taxing the alt by enough, the batteries will only hold the system for a little bit.. and eventually you're going to run out of power. So the alternator setup is the heart of every system, the alternator is the only thing actually "making power" in the whole electrical system. You can add all the batteries you want, but without a big enough alternator you will never be able to play that system for long before the voltage drops and needs to recharge.
not thread stealing but can a mechman 320 ALT get the job done ? ill be running 5k to 9k rms with 3 batteries ???
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
theres people with 4 batteries and 1 ALT well over 10k rms here maybe if you do H/O ALT and xs power battery in the front and back i think you should be cool
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
0 gauge.
yes on 0 gauge
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
0 gauge.
being loud is pretty expensive you need a good wallet or checkings account im well over 3k on cash currently and thats nothing so think about it
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
  • Who's Online   0 Members, 0 Anonymous, 604 Guests (See full list)
