ok i have a sundown 2500 and currently i only have the big 3 upgrade done. my stock alt is a 140 amp and i only have a regular battery up front. what would i need to run this amp at good voltage without clipping would one xs battery in the rear help and if yes which one thanks.
i have checked the website for mechman and dc but they dont list any alternators for my car on ebay ive seen some and are not expensive but i have heard they are not good.
email either of them. I had to email dc for my alt.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
ya email them and they can tool something for your car probably. one battery will help but wont be enough. dont wanna fry anything
i sent them an email although i did want to avoid in having to buy a ho alt. If there to expensive ill just sell the amp or maybe just buy an 2 xs power batteries one for the front and one for the back. i have seen others with the 2500 and there voltage only drops to about 12.5 i know this isnt good voltage but isnt it still good for not clipping the amp?
If you can keep you voltage about 12.6+ with that amp then it should be fine. But you might need more than 2 batts and your going to have to put your batteries on a charger several times.
Just get a 100ah+ battery for the boot for now.
Your alternator will provide most of the power to the amp (obviously engine running).
Just keep an eye on the voltage and temp (by hand) and you'll be fine.
Common sense = win
