R3nOSlaPP Posted January 5, 2012 Report Posted January 5, 2012 guys, serious. at 800 rms. he will not see any difference upgrading to some aftermarket audio related battery. just keep the largest lead acid you can fit under the hood, and upgrade your big 3. Don't go putting a performance exhaust on your moped mmkay? I said (at the moment) as i plan on getting a nice mids and highs amp and most likey switching to the new dc level 3 15 or even level 4. Im just asking a simple question and when you go to the lvl 3 or the lvl 4 what amp are you going to run?? just things to think about when your thinking of buying a battery..dont want to end up buying so small that it will not be able to support the rms that sub and amp pull.. i would go largest you can fit upfront and a secondary in the back..even if its a small system Quote Vehicle: 2017 Chevrolet Silverado High Country Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48 Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3” Subwoofer: (4) B2 Audio XM 8’s Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6 Processors: NavTv M650 (integration), Helix DSP Pro MK2 Silverado Build Log
tlee2 Posted January 5, 2012 Report Posted January 5, 2012 id get the biggest one that would fit Okay thank you, will any xs be good for engine starting? Yep no problem Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
Wassalla Posted January 5, 2012 Author Report Posted January 5, 2012 and when you go to the lvl 3 or the lvl 4 what amp are you going to run?? just things to think about when your thinking of buying a battery..dont want to end up buying so small that it will not be able to support the rms that sub and amp pull.. i would go largest you can fit upfront and a secondary in the back..even if its a small system Not sure yet, i have a massive audio n2 which does 800rms at 1ohm, but i get voltage drop around 13.2 or so on full tilt, just looking to stabalize it, but yes i will see what i can do for both size and budget, Thank you Quote
