phlatliner Posted January 6, 2012 Author Report Posted January 6, 2012 I wanna roll ported and can I tune a box as low as I want even if it is lower then the rated sub frequeny Quote
Hunters21w Posted January 6, 2012 Report Posted January 6, 2012 You still use a port on a 4th order, and yes you can tune lower. I wouldn't go lower than 28 like you said you wanted. To make it easier, adjust your max dimensions so its a square/rectangular. That way your not cutting all sorts of angles. Then see how much space you have. Decide enclosure type..4th or ported. Then build. Sound good? Quote 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
CleanSierra Posted January 6, 2012 Report Posted January 6, 2012 What do you mean your voltage issues are taken care of? Give us an example of the alternator you're running, and number and type of batteries. You legit can't expect anything to happen, except a lot of burnt up equipment if you don't have serious amperage provided by an alt and batteries. Quote Im not the one you want to try to troll. Just a fyi for you.
phlatliner Posted January 6, 2012 Author Report Posted January 6, 2012 I have an 200 alt. A 20 fared capacitor With four 2800 amp kinetic baths how is that not going to hold up Quote
