how would you know its doing 500 watts ? and if it is in deed doing 500 watts and the sub is 400 watts rms i wouldnt do it.
That amp will only do 900 watts at 1 ohm. so each sub would only get roughly 300 watts . and yes it will not sound so good after awhile due to heat build up and running it at 1 ohm. find a sub that does 1200watts @ 1 ohm like the one i shoulded you.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Mikes...now you need to stop.
I think I'm just going to trash this setup, it's given me too much headache and it's not even really capable of the power it was a year ago when i got them.. I'll upgrade to an AQ 2200 and either AQ HDC3 12/15's or SA-12/15's. I'm leaning on the AQ's because they're actually rated for 1000w
I am referring to this.
I would check woofer wiring, then get your gains set correctly. Incorrect gain setting techniques will haunt you regardless of what equipment you're running.
how would you know its doing 500 watts ? and if it is in deed doing 500 watts and the sub is 400 watts rms i wouldnt do it. That amp will only do 900 watts at 1 ohm. so each sub would only get roughly 300 watts . and yes it will not sound so good after awhile due to heat build up and running it at 1 ohm. find a sub that does 1200watts @ 1 ohm like the one i shoulded you.
im not sure what you mean sorry ?
i meant it in a now snotty way i was just wondering where he came up with that if that is what you are reffering to
