FeArZ Posted January 5, 2012 Report Posted January 5, 2012 So I'm completely lost. My truck is so dumb. PUCK Chevy at this point. Charge cable from my alt Now this is where it comes out the engine cover(it's the wire on top) Then it goes to this(no idea what this is at all) Then from there it goes to the Fuse Box(red wire on the right goes into fuse box) So I tried finding out where my charge line came from(what is this big cap for anyway) The charge line goes down under the firewall(I'm lost on this to) So now I'm thinking could I just run another charge line from the alt and connect it to the battery with no problem? Any explaining of the electrical flow of this system would be very helpful. 2009 Tahoe 2000bc Cresendo POWA Need 3500 2 Sundown Zv3 18 high rolled sexiness dual alt bracket with Singer alt(coming soon) Mtx Q(not sure if I'm going to use) Knu wire and RCA's Bass Head Bands Oh and a few pairs of Jordan's
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 Its hard to understand what your asking. It looks like the charge line from the alternator is fused then goes to the battery, If you want to do the big 3 you can simpley add 1/0 from alternator to the battery and fuse it. Ground battery to frame and frame to engine. ALSO ground alternator. Did you buy that truck with a system in it, because the last picture is confusing. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
n8ball2013 Posted January 5, 2012 Report Posted January 5, 2012 you're looking into this way too hard. its a fusible link thats all. run the wire from the alt ot the battery directly and fuse it. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
FeArZ Posted January 5, 2012 Author Report Posted January 5, 2012 Its hard to understand what your asking. It looks like the charge line from the alternator is fused then goes to the battery, If you want to do the big 3 you can simpley add 1/0 from alternator to the battery and fuse it. Ground battery to frame and frame to engine. ALSO ground alternator. Did you buy that truck with a system in it, because the last picture is confusing. No system, this truck was new when I got it. I'm asking would it be okay just to run another charge line directly from the alt because I can't find the Original charge line to disconnect it. So basicly can I have TWO charge lines going to the same battery. This the first time doing the big 3 myself on any vehicle. 2009 Tahoe 2000bc Cresendo POWA Need 3500 2 Sundown Zv3 18 high rolled sexiness dual alt bracket with Singer alt(coming soon) Mtx Q(not sure if I'm going to use) Knu wire and RCA's Bass Head Bands Oh and a few pairs of Jordan's
FeArZ Posted January 5, 2012 Author Report Posted January 5, 2012 you're looking into this way too hard. its a fusible link thats all. run the wire from the alt ot the battery directly and fuse it. I thought I was over thinking it a little bit. I just never seen anyything like this and I looked at other Tahoe build logs and there electrical setup is different. 2009 Tahoe 2000bc Cresendo POWA Need 3500 2 Sundown Zv3 18 high rolled sexiness dual alt bracket with Singer alt(coming soon) Mtx Q(not sure if I'm going to use) Knu wire and RCA's Bass Head Bands Oh and a few pairs of Jordan's
