change the dimension to 23h x 38w x 25d with the port being 20.5h x 5.75w x 33.75l it will give you a net volume of 7.01 port of 16.82 per sq in tuned to 31.52hz. this is all according to the torress box calc.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
3 cubes a woofer is a bit small.. 90% of 15s out like 3.5 4 cubes a piece..id say do 3.5 a woofer..so they would be more efficient on the lower power u plan on using. if you went 4 cubes it might be a bit much for higher power..
them look like some nice ass subs tho
damn let me see what i can do to boost the box volume, other wise does everything else seem fine,
make sure you do like double baffle sub plate and dont be shy with braces.. always use wood glue.. and liquid nails if u wann aget a reall good seal inside
right i'm planning on using 3/4 birch for walls and sides, and hardwood for moldings and bracing. planning on using titebond 2 for holding together the baffles and to seal up where the walls meet
for a "newb" u sure do have a fucking great idea on where and how to start
i should have said that those were my maximum measurements, i probably could go higher but not safely because 22 inches goes above my seat, if it wasnt for my spare tire i could probably go like 40 inches wide. i was also thinking of inverting them but like i said i think it may block my back window.
well this is my second box that ive designed, ive helped build a few small boxes but never anything this big. i think the biggest Ive built was about 2 cubic feet.
both true points, hell my rear view fell off before i even had bass
so say fuck it..and go that extra 1 or 2 inchs above that seat..so ur subs will be happier..and itll be easier to view excursion from the front also
i came across a similar issue when i built the box for my beretta 2 skar vvx 12s in 4 cubes 28hz 16per.. i wasnt going to sacrifice box volume.. becuase that would mean changing how the amps moounted and everything..
so i sat there thinking for literally 2 mins..and yelled out "honey get me the sawzaw" cut the little side panel things out and bam box fit lovely
Posted (edited)
i think currently i'm about 2 inches above the rear seats, as for the port, which would you do? subs up port up, or subs up port back
Edited by bass_stalker
  • Who's Online   0 Members, 0 Anonymous, 570 Guests (See full list)
