this should kinda show the area i have to work with, those dimensions are the most i could fit between the wheel wells and between the hatch and seats
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
would there be any issue with the hatch only being a few inches from the port? i think it may only be one or two inches away
hmmm that back tire is a bitch aint it lol
did you already buy the subs?? bc the website had a VERY hefty pricetag on em.. i said holy shit
actually i'm trading an Xbox for them and a few other things for them, and i wish i had the slim spare tire would be soo much better lol
Edited by bass_stalker
generally u wanna be port distance away from the hatch.. so if u got a 4inch wide port need to be 4inch away from loading wall..BUT depending on application u can move it closer or further away and see how it sounds by ear
ah i may just have to do port up then, see thats where i'm a noob lol i understand the basics but not the things like loading and stuff like that
ever thought about using aeroports??
space is a issue grab a aeroport
i thought of it and that might have to happen, i'm trying to keep the box as cheap as possible but if i gotta get areos to do it right ill wait and save to get em.
what would you figure 2, 4 inch diameter or would i need more, ive never used em.
my last box i did.. was for 2 15" psi reconed tc9s did exactly 7.3 cubes gross volume (gross volume meaning literally a sealed box before any ports in etc etc)... i did 4 4" aeros tuned at 32hz and it was gravy
2 4" ports wouldnt be nearly enough port area
if u wanna improve ur handyman skills u can get some thin walld pvc pipe from lowes or home depot..and heat the ends up and force them over a heavy duty bowl to get the "flared" affect.. ive used both and success with both
Edited by getlocivic
well without the slot port i'm up to 8.56 cubes with 4 4inch areos set to a 10 inch length tuned to 32hz . about 5.87 inches of port area per foot
