Ktraughb's 1998 Blazer Build log
Ive decided to start a build log for my 1998 Blazer. It wont be anything fantastic, and the main idea behind this build is budget. I love spl, but Ill be going for a happy medium with this build--loud and attempt to keep it aesthetically pleasing.
Equipment:
Head unit-Kenwood kdc945BT
Power acoustik 7 band EQ with 8 volt line driver
Two 8 inch mids per front door, 2 tweeters per front dash side
6.5 inch full range speakers
MB Quart Discus 4.80, MB Quart Discus 4.50
2 SVR 1200 batteries, 2 runs 1/0 American Bass Power
Temporarily Orion HCCA5000, (has issues, will be replacing)
2x 15" American Bass XFL dual 2 subs (previously 12s in photos)
And more to come. Its a work in progress, of course after hours and in between all the other stuff I have to work on. This equipment will likely go through some changes along the way as well. I havent decided if I want to attempt a C pillar wall in this blazer, or if that is simply not enough depth. If not, I will obviously stick with some form of street style enclosure, and try to keep it all at the window line. Pics being posted as I go. Thanks for checking it out.
34vo_c29_ua08c.jpgwiring up the amp rack. Mono amp up top, one of the 4 channels below. This is going to be temporary. Something to get me by until I have a better plan for this space.
34vo_2c6_ua08c.jpgfuses in place
34vo_1fa_ua08c.jpg4.80 wired up below.
34vo_c30_ua08c.jpgtemp box we used for some type r subs for a bit. actually gets pretty damn loud and low.
34vo_c6d_ua08c.jpg i know, the edges are very ugly. again, this was temporary, and the baskets on these XFl 12s were much larger than the r's. had to modify it a bit, lol.
34vo_087_ua08c.jpgsome very inexpensive budget equipment for the front doors.
31tv_2e7_ua08c.jpgouter rings
31tv_0aa_ua08c.jpginner rings cut
34vq_377_ua08c.jpgfirst donor panel
34vq_618_ua08c.jpgsecond panel ready for work
first part cut to make room for mids
34vq_4b4_ua08c.jpgstarting to fit the rings
34vq_991_ua08c.jpgrings are mounted. wood hot glue is amazing
34vq_c87_ua08c.jpgtest fit for depth
34vq_6fc_ua08c.jpgside by side shot. not bad symmetry considering the curves in these doors.
34vq_38f_ua08c.jpgfirst one wrapped in fleece and ready for resin. spray glued down.
34vq_99a_ua08c.jpgsecond panel ready for resin.
i left these to dry a little more tonight just for the spray glue. ill start the resin tomorrow. probably end up doing two fleece layers, maybe even mat in between. then on to the bondo. will update once i hit these steps. also more install pics to come with the eq (center console, with din dvd player slot), head unit, wiring etc.
thank you. tomorrow should be a fairly slow day at the shop, so i should be able to get quite a bit more accomplished on these. i got a first layer of resin on one, matted and ready for a second layer. then on to the second one, and lastly start smoothing them with bondo. heres a pic of some of the rough progress on one panel today. i had a mess going. should be better tomorrow. i didnt stretch the fleece as tight as i would have liked so it caused a few issues.
Glad to see you post a build log. I might come down to the shop tomorrow or Sunday, to see the progress in person. I'll be making my building within the next few days. I'm just lazy cause I normally switch setups to often lol.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
larger pics are preferred im pretty sure everyone is lazy like me :)
i will be sure to get a demo when it gets playing
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Apparently I screwed up on reloading the pics. So big they wont even load on my comp. Works on my phone though. If these aren't fixed and this thread needs to be restarted just let me know. Apologies.
Looks very good keep on posting pics :popcorn:
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
