sub level should be at 0, not +6. you will get full 4v on that headunit at volume 37-40, all settings flat.
the hu clips at 35 and i want to set the gain at 25 should i still leave it at 0 or +6
try it set at 0 with volume at 25 using -5db@40hz tone. then you can still turn it up a couple sub level clicks without much worry if a song is quieter like jazz/country. if you use -10db i would not go above sub level 0 to make sure signal stays clean since the gain will be higher using -10db vs -5db
What tone do you suggest to use for people who mostly listen to your tracks?
