series vs. parallel
K I'm. Wanting to run 2 xl m2s off 2 3.5ks and each amp will get its own batt and out of those two battts they'll get there own alt. And I have the choice of d2 d1 d.7 or d.5 ....eather way I wanna run 1 ohm each
Not trying to hate and/or I could be wrong, but something tells me if you don't know the reasoning/answer to the original question you asked you should probably try playing with a little smaller of a system before going so big.
The equipment you mentioned is going to cost a lot of money and is gonna be costly to replace when/if you break it by not knowing how to set everything up properly.
I'm not sure if this is your first system or what, I am just trying to help out. When I started out I had no idea what the heck I was doing and I did ALOT of No no's that I just shake my head about now when I look back at it. I mean blasting my system with the car off, turning the gain all the way up, getting the amp SO HOT, SO MUCH CLIPPING, etc.
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
Id run a 7.5 to the m2s... if your set on 2 amps get the subs in d1s and strapp at 1ohm...... your going to need more than a battery per amp. Do the biggest alternator you can do or multiple if possible and at least 2 xs3100 peramp if possible or those m2s will smoke when you clip your amps on low voltage
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • 9 years later...
1 hour ago, Blazedshuggz said:
Question have a jl audio rd 1500 amp and 2 jl 13w3v3-2ohm subs. The subs are 600rms . question is i came across another 13w3 but is 4 ohm. Would it be bad to run 2 svc 2ohm subs with a 4ohm svc sub together on a mono amp? Dont wanna muff up 800$ amp or 1200 worth of speakers
It's not recommended to wire different ohm speakers together
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
  • Who's Online   0 Members, 1 Anonymous, 2003 Guests (See full list)
