Ok I'm getting back into the import scene, and I got a 99 ej8 with a b16a2 swap. It has a head gasket oil leak, no cooling issues, just oil. That will be changed in the next week. But I'm having an issue that pops up every so often. While I'm driving the best way to describe it is the car dies ( does not turn off) then if I floor the gas it will come to life and it will do it again for a while then drive normal. Also while it's dying if I get off the gas then back on it will continue to accelerate. I haven't been able to replicate this while not in gear, as when it dies I can hit the clutch and rev the engine freely. This engine has seen injector work and possibly head work. I'm thinking the stock si ecu that its running isn't up to task. Any ideas?
Lol, if you find out what it is, post it. My EVO is doing the same thing. I'll do the same.
Clovis Custom Audio 559-392-3600
96 Silverado Single Cab
2-DD9515's Cut-through
1-DDSE Amp
Stock electrical and a couple small stingers, LOL
Did you try any of the honda or civic fourms? You might get better info, good luck.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
