at 2 ohms? what a waste of power... if he had the dual one's it'd make sense. I believeif he gets a T4K he would only be getting one
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
with 2 dual one ohm subs, you wont be able to see a 1 ohm load on a single amp.
On that amp since it has 2 inputs 'A' and 'B' and internally bridged, couldnt you wire both in series so it would be 2ohm to each input and would be 1ohm internally bridged, in theory?
Edited by Eric B
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Yes you can. Series both coils on each woofer to get a 2 ohm load, parallel each woofer to get a 1 ohm load.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
Cheers,
Mick
Yes both of u are right. Series each woofer and run 1 woofer in its own channel @2ohm. The T4k even though it is known as a mono amp, it can be played as a 2 channel amp as well. Like Steve did when he had dual 1 ohm woofers and blew his amps. When he was waiting for repairs on 2 of his amps he ran the 2 subs per amp with the other 2 amps. He series'd each woofer (dual 1ohm) making each sub 2ohm and ran 1 sub per channel. In his case since he has dual 2ohm he would have to go with the T2ks to get his full power.
Edited by CUT BUDDY
00114-1.jpgTEAM MechMan Alternators
if you could switch your sbs for dual 1s i would do 1 T4k
if he gets the 2 dual 2 ohm then he can either run them at .5 2 or 8 ohm. .5 being too low, 2 being a waste and 8...hahaha why
the power series monoblock amps are "set up as 2 channel" amps but internally they are paralleled. so if you wire each sub to 1 ohm then wire one sub per "channel" it will parallel itself down to .5 ohm which can hurt the amp, subs, or set into protect.
get dual 1 ohm subs and wire them to 2 ohm per sub then 1 sub per "channel" and it will parallel itself to 1 ohm
so either switch subs to dual 1s or go with 2 T2ks and run 1 ohm per sub
Edited by Chode69
NoFearX18 said:
trainman0978 said:
so i guess its a good thing i got the universal option
i might just do 4 sundowns but i really wanted the 4kw...
does anybody know the price on a sundown saz-3000?
edit:ill just get the t4kw and run it on my btl now and get another t4kw fro the other btl
Edited by pink_floyd
Lets Go Ski
