1st video catches you up with my system and has a little flex on betrayed/decaf
2nd Video is different aspects of my truck and flex
3rd video is steering wheel flex mainly
PD Decaf flex
1/0 KNU Konceptz oxygen free
AQ 1200.1
sd 2.5 AQ Sub wired at 2 ohms
sony xplod headunit
kicker RCA's
boss 6.5 and cheap tweets
( upgrades soon) check the build log its old but show some love
yea his truck was on.. his little 50 or 60 amp alt cannot keep up.. also dropping to 10v like that.. your amp will NOT NOT NOT last for much longer.
when u voltage drop like that it hurts EVERYTHING.. cars computer fuel pump all that..
if i was you id turn that amp wayyy down before you end up wasting your money .
big 3 upgrade and another battery might be enough to sustain 12v or higher
why is your car off? i'd NEVER show my 1200 10v. you must be insane.
Holy crap 10 volts. Not very good for anything in your vehicle.
yea his truck was on.. his little 50 or 60 amp alt cannot keep up.. also dropping to 10v like that.. your amp will NOT NOT NOT last for much longer. when u voltage drop like that it hurts EVERYTHING.. cars computer fuel pump all that.. if i was you id turn that amp wayyy down before you end up wasting your money . big 3 upgrade and another battery might be enough to sustain 12v or higher
you all must have just watched the ending of one video when the car was on lowest it dropped was 12.3 it does nee dbig 3 but i dont run it like that all the time my 60 amp alternator isnt enough thats right but i ran it 10v for like 30 seconds? and nothing got hot at ALL if you watch the whole video and all 3 it never drops lower then 12.3 volts
infact at the end of video 2 is what you all referring to listen the last 20 seconds of the video that clicking clang noise is me pulling out my key and turning it off 20 seconds of car off play? im fine.
Edited by Relyks
^^ 1st time i let my sundown saz 3500 see 10v magic smoke appeard
lol thats way different ur nearly seeing triple the power i am which requires triple the power to produce
the amp didnt get hot one bit and it was like not even 20 seconds. ill make another video of it just going and ill watch the volt meter
