x2 get there early and talk with the person running the comp. Very good chance they'll let you do a sweep before you have to qualify.
He might even have a sweep disc or someone at the comp should if you can't find one...
Max Killa Hertz....by Bass Mekanik has some sweeps
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Ilovebass, dont worry about thread jack, most my questions have been answered haha.
The comp ive entered is a db drag and its 30sec peak hold. So is it safe to say i ahould find a song that goes across different freqso it juggles around my peak?
I spoke to the guys running comp, the said to come early with a test cd and find my peak, then ill have a bank of songs lableled by the the max and min peaks and play a song from there.
Ia that a reasonable plan?
I would think you want to find tracks that have constant bass in your freq. Sweet spot to fill the 30seconds...
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
I would do it by either sweeps or test tones, and have a bunch o songs/CDs with you for different frequencys.. Find your freq and use a track that has majority that frequency..
Now I'm not positive on this.... but a Long bass note will actually build more pressure in the cabin and bring your score up more so than a quicker note that hits hard... As long as your voltage doesn't drop... But I may be wrong on that one
Laying frame soon.. System has to wait
What dbDrag class is 30 seconds peak hold? You sure he doesn't mean you have 30 seconds to meter and your loudest score at the end is your score? That would make more sense...
So you could burp and then try another freq and another one, but your loudest score is what will stay on the screen = peak hold
Also make sure your batt(s) are fully charged, so no demo's before you plan to meter and let the car run for a while. Also you can rev the motor to 1900RPM while metering which should give you a little more voltage.
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
good luck
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
Dbdrag is a burp...... you have 30sec to do it in... please don't play a tone for 30sec... more like 3 secs max.... sweep doesn't find my peak for me... borrow the dbdrag test disc.. start ay 30 hz and say half volume. Don't touch gas peddle or any settings ask to put the tl on peak hold. Play the track for 4 to 6 secs then move to the next one. So you start at 30hz then advance to say 65hz 1 freq at a time... what kind of car do you have? This way will give you a general idea of what you peak at....when you burp start the track at low volume then roll the volume up to
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 5057 Guests (See full list)
