DaveMusgrave Posted January 13, 2012 Report Posted January 13, 2012 How much wattage, with the right battery bank, do you guys think I could get away with with a 160 amp alt?
Guest Posted January 13, 2012 Report Posted January 13, 2012 what company makes a 160 amp alt? only ones ive seen are those shitty ones from those ebay-only alt sellers. i'd say 2500rms at the most
DaveMusgrave Posted January 13, 2012 Author Report Posted January 13, 2012 what company makes a 160 amp alt? only ones ive seen are those shitty ones from those ebay-only alt sellers. i'd say 2500rms at the most Dodge makes a 160 amp alt, it is the stock alt on my Challenger. 2500 is a little less than what I was hoping to hear...
Toofast4u Posted January 13, 2012 Report Posted January 13, 2012 I had a 160a on my stock charger, I personally went a little over 2k but that was it.
BobbyG2 Posted January 13, 2012 Report Posted January 13, 2012 Well, in a perfect world...160amps x 14 volts = 2240 watts. So that'd be your rms ^ *New vehicle and system coming soon.*
Phrostbyte0311 Posted January 13, 2012 Report Posted January 13, 2012 I wouldn't take it much over 2000 RMS if I were running your application. 2002 Chevrolet Camaro 35th Anniv. Edition Head Unit- Kenwood KDC-X794 Front Stage- Digital Designs DDAW6.5 Mids & DDAT28 Tweets Rear Stage- Kicker KS650 6.5" Coaxial Sub Stage- Sundown Audio SA-15 D2 Mids & Highs Amp- Sundown Audio SAX-100.4D Sub Amp- Audioque AQ-1200D Equalizer- Arc Audio XEQ 5 band graphic EQ 1/2 DIN Electrical- XS Power D3400, Big 3 Knukonceptz 1/0g, Stinger volt meter & Knu accessories Misc.- Over 80 ft.2 Second Skin Damp Pro, Overkill & Lux Liner
Guest Posted January 13, 2012 Report Posted January 13, 2012 Well, in a perfect world...160amps x 14 volts = 2240 watts. So that'd be your rms ^ this is true. but as im sure you know, you have to subtract amps for hvac controls, lights, fuel pump, anything that uses power. so that 160 amps can drop down to 100 pretty easily. but yeah op, it takes power to make power. sure you can run a larger amp, say 3000w, but you wont be able to play it for extended periods of time without draining the batteries and dropping the voltage pretty quick. you'd basically be trying to pull +300 amps from an alt that has 100 amps free and the rest from the batteries.
Mad_Mike Posted January 14, 2012 Report Posted January 14, 2012 I wouldn't do more than 2-2.5k watts RMS. Shouldn't need more than just one extra battery or replace the one under the hood with a good one. You might be able to run up to like 4k rms, but with a lot more batteries and still it won't let you play for very long. If you want to run more than 2500 then I suggest upgrading your alt.
