Fuse Between Runs Question
that looks good man, do that. Thats pretty much how all 7 of my batterys are hooked up. Forget the amps, they all have onboard fuses but right AT each positive terminal i always use something that will burn faster then wire (and the car ;):D )
i would also ground the back "bank" to the frame and also that front bat to the frame as well as to eachother.
Follow my Tweet (Twitter)
i gotta thank you steve
i looked at some of ur pics from when you had the old red ones in
and then when you installed the powermasters
and i thought thats how you did it..
but one question..
when you ground the back 2 batts, do you ground both seperatly or just run a wire from neg to each then ground?
www.myspace.com/trob10
Kenwood eXcelon KDC-x792
Rockford Fosgate Punch 5x7"
DC Audio level 3 12"
DC Audio 1000.1
Stinger wiring
but one question..
i would just connect them together and make the run to the front....now that they are together, just run a single 1/0 from the nearest terminal to a good frame ground and do the same up front. Might be overkill for what you are running but i like overkill :D When your system grows you are already halfway there if you go over the top when you dont need to ;)
  • Who's Online   0 Members, 0 Anonymous, 1270 Guests (See full list)
