caspers bass Posted January 14, 2012 Report Posted January 14, 2012 Well im trying to design a box with torres box calculator and ill be honest i know nothing about building or doing anything with this calculator and im pretty lost so if someone could just help, with dimensions or something lol Quote
caspers bass Posted January 14, 2012 Author Report Posted January 14, 2012 its for an aq sdc 2.5 15 i want like a 4-4.5 cube box tuned about 33hz someone help lol Quote
Cynner Posted January 14, 2012 Report Posted January 14, 2012 Hi Mate, Can you please post what type of box you would like (eg: Ported, Sealed, Bandpass etc) what subwoofer you're using, and the dimensions you have to work with at the most and what type of bass you're looking for, sound quality, deep bass, one note wonder etc. Then I'm sure we can work something out for you. Cheers. Quote I'm not an out of control driver, I'm completely in control.. only sideways.. -Nissan R32GTR running 213KW RB20DET on 14lbs of boost. -Holden Commodore VY SS UTE running stock. -Holden Rodeo mini truck project, soon to be running SR20 on 13lbs of boost. -Landcruiser UTE running 1UZFE v8 11" Lift on 35" MT Classic II's wrapped in Cooper STTs. ^^ and the list goes on..
caspers bass Posted January 14, 2012 Author Report Posted January 14, 2012 Hi Mate, Can you please post what type of box you would like (eg: Ported, Sealed, Bandpass etc) what subwoofer you're using, and the dimensions you have to work with at the most and what type of bass you're looking for, sound quality, deep bass, one note wonder etc. Then I'm sure we can work something out for you. Cheers. i posted sub i want a ported, i want deep bass, its aq sdc 2.5 15. my back is 39in across can go bout 26 deep and height not issue Quote
caspers bass Posted January 14, 2012 Author Report Posted January 14, 2012 cmon now someone help Quote
Joe X Posted January 14, 2012 Report Posted January 14, 2012 This could work: Enclosure Specifications: Fb = 33,031 Hz Vb = 4,081 ft^3 Subwoofer Mounting = Front Mounted External Height = 17 in External Width = 34 in External Depth = 20 in Port Width = 4 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 34 x 17 Left & Right Sides = 18 1/2 x 15 1/2 Top & Bottom = 34 x 18 1/2 L Port Internal Assembly Parts: Front to Back = 14 1/2 x 15 1/2 Extension = 9 x 15 1/2 Quote
caspers bass Posted January 14, 2012 Author Report Posted January 14, 2012 This could work: Enclosure Specifications: Fb = 33,031 Hz Vb = 4,081 ft^3 Subwoofer Mounting = Front Mounted External Height = 17 in External Width = 34 in External Depth = 20 in Port Width = 4 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 34 x 17 Left & Right Sides = 18 1/2 x 15 1/2 Top & Bottom = 34 x 18 1/2 L Port Internal Assembly Parts: Front to Back = 14 1/2 x 15 1/2 Extension = 9 x 15 1/2 alright thanks and is there a way i could use something to make it 3d so i can see it like some program or something lol? Quote
jeremyg Posted January 14, 2012 Report Posted January 14, 2012 (edited) double check all measurements before cutting. Edited January 14, 2012 by jeremyg Quote Google+ Profile
Guest Posted January 14, 2012 Report Posted January 14, 2012 tuning is too low for that woofer. stick with around 37. aq woofers like the higher tuning and can still play low Quote
