Can anyone tell me if 20s will fit on a 1987 GMC S15 (same as a 1987 S10 Chevy) without a lift kit? I want to put 20s on my ride and lower it 3 inches but if they rub ill go down to 18s if they wont rub but i cant lower it ill keep it stock height......basically will 20s fit on a stock height s15 1987 without rubbing if so can you tell me the tire size also?
Scrubby Boy
it should no problem, just gotta make sure its the right offset so it doesnt hit frame before you turn all the way
tire wise its hard to say since u havent lowered it and dont know exactly how much room you have
Yup, this is my buddies 1985 s10
Had 5 in drop blocks in the rear before it was bagged, and drop coils in the front, no cut no rub
Not sure on the tire size though
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
you can deff fit 20s ive seen 22s buy like beatbox said.. you need the right tire and offset.. do some research youll figure it out..check out s10 forum im sure they got alll your answers
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
thank you all so very much i greatly appreciate all the replys im really new to car customization so i was jw...i found some ribs i like but im not sure it said theyd fit an 87 s10 because it seems that noone knows that theyre the same exact thing litterally to every bold but i appreciate it!!!!!
Scrubby Boy
that is definately a sick truck im going to shave all the handles and the gas tank i want it all smooth and silky :D im going flat black out with neon green interior and neon green lighting....i want to find someone within a 75 mile radius of my town to do good airbrush on my tailgate but alas i live in tennessee hah
Scrubby Boy
Easily fit with this bolt pattern and tire size...won't even have to recalibrate speedometer
Offset: -6mm Backspacing: 4.48" Bolt Pattern: 5-475 Rec. Tire Size: 255/35-20
Edited by stroupe79
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
