bass_stalker Posted January 15, 2012 Report Posted January 15, 2012 when you add another baffle to your box on torres where is it calculated, on the inside or on the outside, meaning do both baffles go into the inside then sit flush, or is one bigger then the other and just sits on top JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Joe X Posted January 15, 2012 Report Posted January 15, 2012 If you add a second baffle on the same external dimensions you loose airspace, you can make the baffle layers the same size or different that changes nothing, the airspace lost is the same.
