Rd Alpha Max Posted January 16, 2012 Report Posted January 16, 2012 I am going to be building a box for my friends nightshade 12. It is going to be a slot port but i am very confused on how to tune it. Every length i put in it has a really high frequency. I might just be something. I am a sub box noob so don't go too hard on me System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
Rd Alpha Max Posted January 17, 2012 Author Report Posted January 17, 2012 i want the box to be around 2 cubes and tuned at 30hz. dimensions around 15h x 25w x 15d. HELP PLEASE System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
certifiednut Posted January 17, 2012 Report Posted January 17, 2012 a port that is 14.5x 1.5x 33 w/3 common walls with the box size u mentioned has a port length of 33in are you using the torres calculator? the port is kinda skinny though these orphans aren't going to feast on themselves
Rd Alpha Max Posted January 17, 2012 Author Report Posted January 17, 2012 yeah I tried the Torres. i wanted the port bigger though. is there any way it could be bigger? And what do you mean by 3 common walls? System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
certifiednut Posted January 17, 2012 Report Posted January 17, 2012 its about 3/4 of the way down on the first page of the torres calc. thread, it just means it is on an end or top or bottom and goes all the way across, also there is a box on the calc. that asks how many common walls. i plugged some numbers in there and with that small of a box it looks like any bigger port and you need a port about a mile long. these orphans aren't going to feast on themselves
412 CVX Posted January 17, 2012 Report Posted January 17, 2012 shoot me a PM, i could design you something Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Rd Alpha Max Posted January 17, 2012 Author Report Posted January 17, 2012 Alright, thanks for the help though System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
Rd Alpha Max Posted January 17, 2012 Author Report Posted January 17, 2012 shoot me a PM, i could design you something PMed System 1997 Saturn SC1 Trunk Wall 2 Obsidian d2 12s 4.1cu. @ 30hz SAZ 1500d @ 2 ohm 1/0 Welding Cable Stock alt Big 3 in 1/0 Welding Cable
