Subsonicwhat Posted January 17, 2012 Report Posted January 17, 2012 I will be using 4 nightshade v.2 18s on 2 saz 4500s. Im looking to do a 2:1 ratio for this box...im just not sure how many cubes i should use in my sealed section. Im wanting this build to be very musical not so worried about spl. Would you just stay with the original box size, 4 to 5 cubes? Or should i shrink it up, or even make it larger??? And port area for the ported section, im guessing 10 to 15 sq in per cube? All help would be greatly appreciated
Sanitarium Posted January 17, 2012 Report Posted January 17, 2012 2.5 per sub sealed should do ya well. stuff in about 1 pound per cube of poly stuffing.
99fullsizechevy Posted January 17, 2012 Report Posted January 17, 2012 Closer to 20sqin per cube tune up around 49-50hz stay in recommended specs for the ported and sealed cubes Laying frame soon.. System has to wait
Socky Posted January 17, 2012 Report Posted January 17, 2012 I've heard singer recommend 1:1 a few times to give a flat response for daily. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
Subsonicwhat Posted January 17, 2012 Author Report Posted January 17, 2012 So many different answers! So im still not completely sure what would be best. Anyone else have some input?!?
99fullsizechevy Posted January 17, 2012 Report Posted January 17, 2012 So many different answers! So im still not completely sure what would be best. Anyone else have some input?!? I've done a ton of reading thru endless threads trying to conquer a 4th order a that's all the important info I've came across that's worth anything but maybe someone will chime in What the space you have to work with Edit: I would say around 2.75 cubes each sealed and 5.5 cube ported after displacements where as 3 sealed 6 ported would be good on rms and they recommend 4.5 when throwing 2500 each ported, so after rise and such you should be seeing around 2k-2200 Thats all based of a post in another thread I found with the search button Laying frame soon.. System has to wait
Subsonicwhat Posted January 17, 2012 Author Report Posted January 17, 2012 I have a tahoe so space wont be an issue. Ok so now your saying don't go with specs?
