exactly so you cant fit two 8 gauge in that first + or the - on the way to amp -....... 12 gauge is more than sufficient
youd need some type of connector to reduce the size of the wire
4 ga?! as speaker wire? uh... thats gonna be a bitch to fit, and WAY overkill, its only 1000 watts
and since you are using 2 12 gauge to go from to each positive that allows for 950w, as stated, 10 if you can fit it but 12 is used in almost all applications
Well my friend is at bestbuy and the reason I need a fast answer was he offered to use a 10$ off coupon and get me somethin since he knows I need it...what should I tell him cuz he's still there.
A vitrolic, megalomaniacal sadistic psychopath.
i like to use 2 12 gauge of equal length positive and two 12 gauge equal length negative, and twist the 2 positive into one, then into amp terminal and same for negative, it is the same as the rockford fosgate wiring diagram, 2ohm dvc to 1 ohm, if you are concerned about loss of power due to wire size, that would help alot.... and in your case of bl's, why not
Edited by decafcappucino
that sounds good thanks man
i wouldn't do any less than 12ga and no bigger than 8 ga.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I already got the 12 gauge speaker wire. Instead of splitting it up Im just going to combine the ends together...So it can carry the power of 2 12 gauge wires...
sounds like a plan. post pics bro.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • 3 weeks later...
Out of curiosity, would using one run of 14 gauge along with one run of the 12 work? I only ask because I already have a good amount of 14 gauge so it will save me a little. If I understand correctly, electricity follows the path of least resistance, so once the 12 gauge becomes over powered will it move over to the 14? I know this probably sounds confusing but I want to wire my subs today and don't think 15' of 12 will be enough.
  • Who's Online   0 Members, 0 Anonymous, 4447 Guests (See full list)
