im wanting to be tuned to 34 hz
would i be better of doing a
(my min. dimensions) 4.46cubic feet box with port sticking outta the box
or
(my max. dimensions) 6.685cubic feet box with port inside the box
stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/
Get chevyboy95 in here
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
this is her box i forget what i tuned it to the first time but it was in the high 30hz not a tall box because i didn't want the box to be to close to the hatch she only has 40 dollar woofers and an interfire amp rated at 600 watts rms at 2ohm and we have the ports firing back
vehicle-02 toyota celicawoofers-groundshaker g-s1 10" woofersamp-SUNDOWNAUDIO SAZ 3500battery-1 C&D battery
whats the dimension of the box and whats the port volume?
It all depends on what you can fit you need an internal net volume (Vb) around 3 cubic feet for those subs, so here is a design suggestion for those settings I have added a double baffle (top face) on those dims:
Enclosure Specifications:
Fb = 34 Hz
Vb = 3 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 13 in
External Width = 26 1/4 in
External Depth = 25 in
Port Quantity and Dimensions:
Number of Ports = 2
Aero Port Diameter = 4
Aero Port Length = 16,591 in, 16 9/16 in
Vertical crossbracing is recommended as well. You can play around those dims with the Torres so see what you come up with.
In this suggestion the ports go fully inside the box.
Edited by Joe X
  • 3 months later...
after more learning and reseaching and more playing around with the torres porgram i came up with this..
hows it look?
You need 3 4" ports like somewhere around 19" long to get enough port area and tuning freqency.
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
Port area range says 35-51". You have 25".
Pioneer deh-8300UB
Big 3 upgrade
I might be off a tad I just did a 3.5 cuft box not a 3.9cuft but 3 4" ports put me right under 35hz n they were 19" long.
Pioneer deh-8300UB
Big 3 upgrade
So hold on..
I need to do three 4in ports that all 3 are 19in long?
Or 19in total from the 3 ports?
