Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO They were telling me that the subs are actually .7 ohm so I don't know i'll just give them a call tomorrow. But I really do not think it is a battery/electrical issue at all or my lights would dim a lot more. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO The subs are dual 1, is that bad? And now that i look at it on the fi car audio website.. it says dual 2 ohm subs only have 1k rms? is that a mistake? Or is it actually only 1k rms Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
MIKE-2U Posted January 20, 2012 Report Posted January 20, 2012 check ohmload with ddm and report back 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 check ohmload with ddm and report back I really don't know what this is... Sorry i'm new to car audio. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
kraz1021 Posted January 20, 2012 Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO The subs are dual 1, is that bad? And now that i look at it on the fi car audio website.. it says dual 2 ohm subs only have 1k rms? is that a mistake? Or is it actually only 1k rms dual 1 subs are perfect since you have a amp that is 1ohm stable you wire the subs in parallel to get a 1ohm load at the amp....im not sure on the BLs power handling as i have new owned or used one...but the site says the dual 1s are 1000w rms and dual 2 are 1500w rms for the 12s
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO The subs are dual 1, is that bad? And now that i look at it on the fi car audio website.. it says dual 2 ohm subs only have 1k rms? is that a mistake? Or is it actually only 1k rms dual 1 subs are perfect since you have a amp that is 1ohm stable you wire the subs in parallel to get a 1ohm load at the amp....im not sure on the BLs power handling as i have new owned or used one...but the site says the dual 1s are 1000w rms and dual 2 are 1500w rms for the 12s And what is parallel? Should they be wired to 1ohm or 2 ohms? They are currently wired at 2 ohms. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
kraz1021 Posted January 20, 2012 Report Posted January 20, 2012 wiring diagram ^^^^^^^^^its the diagram on top
kraz1021 Posted January 20, 2012 Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO The subs are dual 1, is that bad? And now that i look at it on the fi car audio website.. it says dual 2 ohm subs only have 1k rms? is that a mistake? Or is it actually only 1k rms dual 1 subs are perfect since you have a amp that is 1ohm stable you wire the subs in parallel to get a 1ohm load at the amp....im not sure on the BLs power handling as i have new owned or used one...but the site says the dual 1s are 1000w rms and dual 2 are 1500w rms for the 12s And what is parallel? Should they be wired to 1ohm or 2 ohms? They are currently wired at 2 ohms. you cant wire 2 dual 1ohm subs to a final load of 2ohms,its either 1ohm or 4ohm
Hadec Posted January 20, 2012 Author Report Posted January 20, 2012 some questions 1st how did they wire 2 dual 1 subs to a final impedence of 2ohms.if you have dual 1 subs they should of wired it to 1ohm or 4ohms 2nd whats your electrical consit of,i know u have a stck batt(which should be upgraded running that much power) but have you done the big 3,do you have a HO alt. by professionals im taking it that a local shop did your install.if they told you they hooked up 2 dual 1ohm subs to a final 2ohm load then they must not know what their doing or talking about IMO The subs are dual 1, is that bad? And now that i look at it on the fi car audio website.. it says dual 2 ohm subs only have 1k rms? is that a mistake? Or is it actually only 1k rms dual 1 subs are perfect since you have a amp that is 1ohm stable you wire the subs in parallel to get a 1ohm load at the amp....im not sure on the BLs power handling as i have new owned or used one...but the site says the dual 1s are 1000w rms and dual 2 are 1500w rms for the 12s And what is parallel? Should they be wired to 1ohm or 2 ohms? They are currently wired at 2 ohms. you cant wire 2 dual 1ohm subs to a final load of 2ohms,its either 1ohm or 4ohm So thats the problem then..? I'll bring it back and get 1 ohm wiring. Working on my first car audio build ever! Currently have: - 1996 Lexus LS400 sedan - Diablo Hellfire Proto Amplifier - (2) 12" Fi Bl Subwoofers - Vented subwoofer enclosure from Perfect Soundz - Installed by Perfect Soundz Needs: - Battery: probably XS Power 12V 2400 - "The Big 3"
Rebel4055 Posted January 20, 2012 Report Posted January 20, 2012 What you should do is try working on it your self. I don't think ohm load is a issue here. When the amp cuts off does the amp go into protect? Or just the power just goes out. If the subs are dual 1 they probably wired them at 1ohm or 4 ohm which isn't a issue. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
