i didnt mean urs were, just any that are need to come out of those enclosures.....
yeah, definately some lost db's moving the lid and not sending the pressure forward....
whats your exact enclosure size and tuning and port sqin, along with max dimensions a new box could be
It is 3.33 net cu. ft. and 3.98 total cu. ft. If you go on the Audio enhancers website its the TX 400 series box the dimensions are good on it. I just need the height of the box a lil shorter i need it to be 17" or less as far as being able to fit it in my car properly.
Team MaxRetribution
Si Vis Pacem Parabellum
ok so that helps alot going to that website.... so if you got the skills... make your own box
http://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0
this should sound much better and you probably will gain db's since its not prefab. the fact its tuned lower is for better response and more port surface area to accomodate higher notes/spl
modify that program at the bottom to whatever specs you need to change
dont bother with the xmax its never correct
does this help?
talk to status about that mtx sub! he had a 12 inch and hit a 146.4 with it. with 1500 watts from a memphis amp mcd1500 I think.
jeez that sub gets loud
stratus*
things that help with spl....
build tune build tune build tune build tune then tune again, more power the better. If you have not, do the big three. More runs of power wire the better, helps with resistance. Try higher tuning as stated above. Find the fresh air vents in your car and seal them up. Sound deadener does not always help with yielding a higher spl in some cases it can hurt your spl. The most important thing is to find out what your car likes, and then start adding little things here and there. Get yourself a TL or find someone that has one, cause you will need it to find out exactly what kind of gains you are seeing.
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
