I honestly think 4^3 net would be fine, but would tune to 36hz. The motor and suspension allow it to play well below tuning with no issues, but it isn't a low end sub. Tuning to 36-37 should allow you to play a much wider range of frequencies with strength.
so basically you mean 4 cubes and tune to 36 would be the best?
Here is the response plot if the aq sdc 2.5 4cuft@33Hz:
The HDC315 behaves very differently than this sub in the same box:
With the typical gain dip just above tuning frequency so 33Hz is bad for the HDC3 on 4 cuft but not so for the sd2.5.
OP so for a 36Hz tune the box would be like this:
Enclosure Specifications:
Fb = 36 Hz
Vb = 4 ft^3
Subwoofer Mounting = Front Mounted
External Height = 17 in
External Width = 32,15 in
External Depth = 20 in
Port Width = 4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 32 1/8 x 17
Left & Right Sides = 18 1/2 x 15 1/2
Top & Bottom = 32 1/8 x 18 1/2
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 15 1/2
Extension = 3 11/16 x 15 1/2
Honestly the 33Hz tuning is fine for the SDC2.5 but tuning is slso a quesion of taste so there are both options.
