15" T-Line sub box?
This is that multi design tline box. If you look inside the mounting hole, you see another mounting hole. A sub can mound inside, and a sub outside. and the middle chambered shared about 1.6-1.8cf/ I also had a solid plug where I could mount a sub inside the box, plug the outside for a 4th order design
Laugh at my BEAUTIFUL redome job, I dont care lol. I didn't have the correct glue to fix the dome back then ;)
this is a very old basic rendering of how this box looked
What is the purpose of having two mounting holes? & Does that extra space between them affect anything?
System:
Basically Stock
In process of upgrading
two mounting holes? to mount one sub inside, and one outside. Its called Compound Isobaric. kind of old-school design.
The Compound design peaked at a lower frequency, 32-34hz but was more narrow banded about 25-36/38hz with a pretty steep roll off.
Band pass had a wider response from 25-50hz and was best sounding and very loud
choked tline where just one woofer was in the front, firing into the air space then in to the line was loudest at higher frequencies 42hz. Mainly played 35-50hz best. At one time I attempted to calculate this as a ported box, and wasn't that far off. BB6.0 calculated it as a 45-50hz spl based box. I may be off a little, its been about 5yrs at least
With the front board off, and one sub mounted normally on the inside baffle, it was a standard tline. This was pretty flat/SQ sounding, but NOT the loudest at all
I kinda thought it'd have something to do with isobaric but that sealed part totally threw me off, it's a pretty awesome design, how would you come up with a design like that?
System:
Basically Stock
I used compressible weather stripping and washers with rubber gaskets. No air leaks at all
  • Who's Online   0 Members, 0 Anonymous, 3304 Guests (See full list)
