help with cut sheet for 2 15 sa sundown
tejarillo
i need help with a box Im making any input is greatly appreciated.
the box is 22 inches high by 40 inches wide and 20 inches in depth
L port or port with a 3 common wall port 29 inches long by 4 inches wide tuned to approximately to 32 hz
with a double baffle to make the subs flush to the box
baffles 2 pieces 34 1/2 x 20 1/2
sides of the box 2 pieces 20 1/2 x 18 1/2
top and bottom 40 x 20
back 40 x 20 1/2
port part 1 20 1/2 x 13 3/4
port part that vends 20 1/2 x 16
the cut sheet i came up with is this if anyone with more experience can lead me in the right track or tell me if my calculation are right thanks
So I set your dims and tuning and here is what comes up:
Enclosure Specifications:
Fb = 32,108 Hz
Vb = 6,598 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 22 in
External Width = 40 in
External Depth = 20 in
Port Width = 4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 35 1/4 x 20 1/2
Front Internal = 34 1/2 x 20 1/2
Back = 40 x 20 1/2
Left & Right Sides:
Side 1 = 18 1/2 x 20 1/2
Side 2 = 17 3/4 x 20 1/2
Top & Bottom = 40 x 20
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 20 1/2
Extension = 3 x 20 1/2
Thanks im going to double check what i did wrong. And do you think its a good box for 2 15 besides how come side 1 and side 2 are different is that where the double baffle comes into play
You picked a lower than recommended tuning (of 35Hz) and that's good for rap and the likes but maybe not so much for rock type of music. Here is an assembly diagram (generic dimensions):
Sides are different because of the assembly style.
  • Who's Online   1 Member, 0 Anonymous, 1143 Guests (See full list)
