how much second skin do u think i need?
1 Audioque 10" SD 2.5 on 1200.1 d ( 870watts rms 2 ohm )
in 35 hz 2 cu.ft
in a single cab 1991 toyota pick up truck.
how much to do this back wall and the doors roof doesnt really see much harm as my back walls and doors.
if you could price each one doors , wall , and roof separately id love to hear how much to do each point.
Each door, you're looking at maybe 2-3 sq. ft. each.
Roof, 4 sq. ft.
Rear wall, 4 sq. ft.
All totaled up you're looking at 14 sq. ft. + or - a bit, so a Door Pack of Damp Pro or a 20 sq. ft. pack of Damplifier would do the trick.
You'll achieve at least 25% coverage per panel with that amount (probably closer to 40%). If you want more of the sheet metal treated, go with a little bit more.
Because of how flat those panels are in your Yota truck, Alpha Damp would be an awesome choice and with a single 20 sq. ft. pack you would have MORE than enough.
Cool? :drinks:
Have a question about Second Skin? E-Mail me!
well that back wall rattles like hell and them doors to so it sounds good but i wanna stop rattling much as possible
and will this help it sound better overall in everyway like bass wise ( even though the rattling wont be there ofc ) will it make the bass sound better in the cab?
edit :matter infact go to my build page 4 read what me and a other yota owner were talking about near the end of the page.
Edited by Relyks
i have another solution for you, buy as much as you can, use what you need and then send the rest to me :drink40:
I second this motion ;). I have never had an issue with unloading my leftovers...
Rattles can be dealt with in another way that doesn't require sound deadening.
If it's trim rattles, look at replacing old, worn, or broken trim clips as well as installing some cushioning behind the trim to prevent the metal on plastic contact. Our OverKill closed cell foam works great for this because it's so thin you can install it almost anywhere and not have any issues with poor or bad fitment.
And yes it will help the overall sound and quality inside the vehicle.
lol well rattling is the rear wall and door wells.
Then you're probably going to want a bit more coverage per panel. A Trunk Pack (36-40 sq. ft.) would cover well and leave you with leftovers.
isnt the trunk pack the same size as alpha damp pack
LOL, yes... I shouldn't be answering questions when I'm tired.
I meant BULK Pack.
Trunk Pack - 20 sq. ft.
Alpha Damp - 20 sq. ft.
Bulk Pack - 36.5 sq. ft.
  • Who's Online   1 Member, 0 Anonymous, 1536 Guests (See full list)
