Nightshade V.2 12 Box help
I am trying to make a box design for my friend's Nightshade and this is what i have. He wants it tuned low so it is tuned to 30hz. Do you think a 2" port is too small for it?boxdesign.jpg
System
1997 Saturn SC1
Trunk Wall
2 Obsidian d2 12s
4.1cu. @ 30hz
SAZ 1500d @ 2 ohm
1/0 Welding Cable
Stock alt
Big 3 in 1/0 Welding Cable
With a driver displacement of 0.15 (estimanted) cubic feet and dismissing your bracing which you don't provide measurements this would work:
Enclosure Specifications:
Fb = 30,012 Hz
Vb = 1,979 ft^3
Subwoofer Mounting = Front Mounted
External Height = 15 in
External Width = 31 in
External Depth = 14 in
Port Width = 2 in
L Port Internal Assembly Parts:
Front to Back = 10 1/2 x 13 1/2
Extension = 22 1/2 x 13 1/2
If you let me know the missing information I could get more accurate. Two inch port width can work.
That wasn't directed toward you, but download torres calculator here. RE is not the most accurate.
That was directed towards Joe X.
More box builds
I'm with captain stupid.
yeah it should work alright. depending on how long it is, it should give you around 14-16 square inches of port per cube.
i would, however, add a second baffle to this. it's a heavy ass subs and it's gonna be moving a lot. single baffle will be flimsey.
More box builds
Do you still have the sketchup model? i'll show you what i'd do.
More box builds
  • Who's Online   1 Member, 0 Anonymous, 1692 Guests (See full list)
