Air Bags for a Astro Van
Also i would use a firestone 2600, or something similar as far as size goes. you'll have to notch the rail out a bit when you mount them, but you'll be able to get 6-7" of lift up front easy. I welded up a seperate shock mount on the outside of the rail also.
For the rear a tri 4 link would be best, but that requires a LOT more work then what I did mounting over axle. It's basically bodydropping the rear half if you link it properly.
Posted Image
You can see how much you have to cut away up front, this gives you clearance when the bag is deflated so it doesn't rub.
Posted Image
and a little something for inspiration ;)
Posted Image
old school pic here..pair of AA 100hc's pushing 12 15's ;)
Posted Image
Wow, I'm actually nobody mentioned astrosafari.com or it's backup forum. :)
This is something I'm also interested in, after the first 3 priorities are taken care of. 1) body fixed, 2) loud system, and 3) 4.3 to 350 swap.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
  • 7 years later...
