I tuned this headunit to the amplifiers like at volume 24 but i was wondering what is the maximum unclipped level of this headunit if any one knew by chance?
I think the max is 32 but i want to know what is the highest i could go so i can retune the amps.
Also i have everything to flat but my subwoofer level control should be at 15/15 then set my bass amp right? because my bass dissapears if i lower it but just want some good input.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Every h/u is different though. For example I got two of the same model number kenwood radio. One distorted at 27 the other at 26. So best thing to do is get a dd-1 or scope and test it.
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
The max is 35.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Thanks for the response but im pretty sure the headunit goes up to 32 (its my girls setup so in her truck).
I got help on my pioneer double din here last week so can you double check if this headunit doesnt clip at max? Or do you know any one that does so i can know how high i can go with it without clipping?
You guys sure its clip free up to 35? I could have sworn in the "headunits clipping thread" that someone said 24.
Big 3 with Yellow Top
The max is 35.
My fault its not my headunit so i was kinda guessing so it is 35, do you know where it clips at soft clip or whatever?
Yeah thats where i set the bass amplifier at 24, but i only had the sub level at 12/15 so i dunno if i should go 15/15 then retune the amp, but if its higher than 24 i could set it with the volume higher like say 35/35.
The max is 35.
Nope, but on my unit, I can hear audible distortion in the 24-26 range. I don't go passed 23 on mine.
(1) Mechman 240
TEAM NWSPL
155db outlaw
What do you have your 105 set at as far as eq and stuff? When you say distorted did you test it with the stock speakers hooked up to the headunit or is that distorted signal you hear is from running it with your external amp?
I like to first hear speakers connected to the headunit then turn it up the highest i can go without it distorting which in my pioneer was 60/62, so im hoping someone has done that for me on the cda 105.
Whats is your sub level control set to ?/15
