Looks good man. Did you even paint the chevy logo on the wheel?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
heh.. yes. i didn't take a pic of it but even painted the chevy logo on the front grill black w/ a white outline
Looks awesome man. Well done, mind putting up the basic steps you took?
i decided to go with the dupli-color spray paint & some of those dupi-color touch up paint vials. the dash piece just pries right off so i removed that and laid it on the ground (with newspaper under it) & gave it a good coating with the spray paint, let it dry, then went over again with a 2nd coating. once it dried i put it back on.
the other panels i ended up using a combination of masking tape & newspaper to cover up the areas around that i did not want to get paint on & then spray painted those as well. i then used the touch up paint to get any edges/corners that needed it... as well as i used the touch up paint on the chevy logo on the steering wheel.
and yes, i made sure that the touch up paint & the spray paint were identical colors. you can find the proper match you need on dupli-color's website to.
