sup guys my names shawn im new to the forums my car is a 94 g20t. i just got a new deck yesterday i traded my flip out indash+money on his end for it. overall i love this deck. it sounds amazing. heres some videos let me know what you think. highs and mids are toxic audio with toxic tweeters in the pillars (bought the car like that im going to change them) also a kenwood 10" free air sub in the decklid wich im also going to be changing. sorry for the dark videos.
highs and mids
bass
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
yeah ima take the sub out of the decklid and build a custom box for 2 10" subs and put 2 kenwoods in it for now then put 2 sa-10" and use the hole i cut in the decklid as some kind of port. then ima upgrade all the interior speakers and get amps for the highs and mids and new amp for the subs. the toxic speakers are ran off the stock amp currently and i only have a 300 watt kicker amp to the sub. sub wattage is 300rms and 1000peak so it can handle alot more than its getting.
New build
If the sub is rated for 300 w rms, why do you think it can handle way more ? Because of the 1000 w max rating ?
give it 300 and that's it. It really doesn't need anything more, only a good box. Or it won't last long.
good luck
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
true that. my noob side came out a little bit. im planning on doing a build with 2 of them so im going to get a new amp. if i have 2 of these 10's prolly a 1000-1200 watt would be good huh? i want it to be loud. later ill upgrade subs to sundown audio 10's
New build
  • 3 weeks later...
heres a few pics i took of my car yesterday. enjoy smd fam.
New build
couple more
the deck in my car
also where i put my amp in my car as a temp thing
where it was before
and after
and i have a whole trunk right now
New build
got my exhaust done.
sounds nice not loud at all
what you think?
New build
my girl has the same car and i wanna take factory cd player and put aftermarket in ...can u tell me what i would need?..
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
you need a wire harness (varies depending on year) and a antena adapter. when you pull out the factory radio you will need to take off the mounting brackets from the factory radio and use it on your aftermarket one. also for the wire harness there is no ground wire i dont know why they are just like that so you will need to use the ground wire from the aftermarket deck and ground it somewhere behind the dash. (i used the mounting screws and works just fine) let me know if you need any more help
New build
